Ok I know that you said no other reccomendations but you can get a fully LOADED inspiron e1705 for less than the 1710
same proc. ram cpu gpu bigger hd better cd/dvd drive same sound drivers same vista distro....):
PROCESSOR Intel® Core™ 2 Duo T7200 (2.00GHz, 4MB L2 Cache, 667 MHz FSB) edit
OPERATING SYSTEM FREE Upgrade to Genuine Windows Vista™ Home Premium with 1GB of memory edit
LCD PANEL 17 inch Wide Screen XGA+ TFT Display with TrueLife™(glossy) edit
MEMORY 2GB Shared Dual Channel DDR2 SDRAM at 667MHz edit
HARD DRIVE 250GB 5400RPM SATA Hard Drive edit
OPTICAL DRIVE 8x CD/DVD burner (DVD+/-RW) with double-layer DVD+R write capability edit
VIDEO CARD 256MB NVIDIA® GeForce™ Go 7900 GS edit
SOUND OPTIONS Integrated Sound Blaster® Audigy™HD Software Edition
BATTERY OPTIONS 80 WHr 9-cell Lithium Ion Primary Battery edit
WIRELESS CARDS Intel PRO/Wireless 3945a/g edit
BLUETOOTH OPTIONS Dell Wireless 355 Bluetooth Internal (2.0 + Enhanced Data Rate)
1961$ and you could add in a 4 year at home warrenty for less than the 1710 still. Also the alienware has a pretty lacking graphics card.
