Need Help, Computer Problem
Raistrick
Hi,
im having a problem with my PC, my computer is hooked up to my 32" LCD TV, the computer turns on but it says No Signal on the TV, Im not too sure what it is, but i think it could be my graphics card that could have broken,
Any one got any suggestion what it could be?
Thanks
Try a different monitor or video card? Could be refresh rates aren't compatible. Was it working and just stop all of a sudden?
Thanks
Same thing happened to me.
What TV do you have and what video card?
it was working fine for a while, then it just stopped all of a sudden, is a video card same as graphics card, if it isn't i don't have a video card and that could be a problem, but it use to do it before i hooked it up to my TV. It works fine for a while then it just cuts off and says no signal even though the computer is working.
A video card is the same as a graphics card. You need to try a different monitor, cable, and graphics card to sort it out. Try hooking up a regular monitor up to it first, the input on the tv could have just stopped working.
