Need help on my first build
What do you guys think of this build? It comes up to about $1300 after ship and tax of www.Ibuypower.com. The optimal settings gauge was maxed on all their tested games (don't know how reliable that is tho)
1 x Case ( Antec DF-85 Full Tower Gaming Case - Black )
0 x Case Lighting ( None )
0 x iBUYPOWER Labs - Noise Reduction ( None )
0 x iBUYPOWER Labs - Internal Expansion ( None )
1 x Processor ( AMD Phenom™ II X4 955 CPU (4x 3.20GHz/2MB L2 Cache) )
1 x Processor Cooling ( Liquid CPU Cooling System [AMD] - [Free Upgrade] Standard 120mm Fan )
1 x Memory ( 8 GB [2 GB X4] DDR3-1600 Memory Module - Corsair or Major Brand )
1 x Video Card ( AMD Radeon HD 6970 - 2GB - Single Card )
1 x Video Card Brand ( Major Brand Powered by AMD or NVIDIA )
1 x Free Stuff ( [Free Game Download] - Just Cause 2 - Free with Purchase of NVIDIA Video Card )
1 x Free Stuff ( [Free Game Download] - Total War: Shogun 2 - Free with Purchase of AMD Phenom II Processor + Radeon HD 6000 or Higher Video Card )
1 x Free Stuff ( [Free Game Download] - Deus Ex - Free with Purchase of AMD Phenom II X6 Processor / Radeon HD 6850 or Higher Video Card )
1 x Motherboard ( Gigabyte GA-970A-D3 -- AMD 970 )
1 x Motherboard USB / SATA Interface ( [Free] Internal USB 3.0 PCI-E 2.0 x1 Expansion Card )
1 x Power Supply ( 1000 Watt -- Extreme Gaming Series )
1 x Primary Hard Drive ( 2 TB HARD DRIVE -- 64M Cache, 7200 RPM, 6.0Gb/s - Single Drive )
0 x Data Hard Drive ( None )
1 x Optical Drive ( 24X Dual Format/Double Layer DVD±R/±RW + CD-R/RW Drive - Black )
0 x 2nd Optical Drive ( None )
0 x Flash Media Reader / Writer ( None )
0 x Meter Display ( None )
0 x USB Expansion ( None )
1 x Sound Card ( 3D Premium Surround Sound Onboard )
1 x Network Card ( Onboard LAN Network (Gb or 10/100) )
1 x Operating System ( None- Pre-formatted Hard Drive Only )
1 x Keyboard ( iBUYPOWER USB Keyboard )
1 x Mouse ( iBUYPOWER Internet Mouse )
0 x Monitor ( None )
0 x 2nd Monitor ( None )
0 x Speaker System ( None )
1 x Power Protection ( Mighty Voltage Regulator - Opti-UPS SS1200-AVR )
0 x Headset ( None )
0 x Video Camera ( None )
1 x Advanced Build Options ( Tuniq TX-2 High Performance Thermal Compound - The best interface between your CPU and the heatsinks )
1 x Advanced Build Options ( Professional wiring for all cables inside the system tower - Achieve exceptional airflow in your chassis )
1 x Advanced Build Options ( Professional wiring for all cables inside the system tower - Basic Pro Wiring )
I'm not dead set either way, cause I'm not sure how either will effect the computer. If you think AMD would be better then ill go with that.
amd will be cheaper, and perform well in games. Intel will perform better, but your not going to see much difference in game.
What do you guys think of one of these two graphics cards instead of the one posted by wolfeking. My concern with the one posted above is the mixed reviews on the card and seeing as the other two are around the same price, have similar listed stats, lifetime warranties (limited), and a lot more concise reviews I was wondering if it would be better to buy one of these:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130587
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130590
Just a last update to any one who is curious. The com runs like a dream, I've tested it on dragon age 2 with the highest video settings (including the higher resolution pack) and it runs SO smooth. Thank you everyone for you help!
