Need Help Water cooling issues
Discussion in 'Computer Cases, Power Supplies and Cooling' started by Jeremy T Kai, Feb 12, 2019 at 4:02 AM.
  1. Jeremy T Kai
    Jeremy T Kai New Member
    5
    My buddy has a full blown water cooling setup. And for some reason the fluid is not cycle thought the lines all the way. Already checked for blocks or clinks in the line and all is clear. And the is a good seat on the cpu and gpu. Any idea what can be causing these issue. Any help would be good.
    Thanks inadvice
    Jeremy
  2. beers
    beers Moderator Staff Member
    8,193
    What's the pump using for a power source? If it's pwm for a DC pump or configured with a fan curve then it's usually no Bueno.
    What components are in it?
  3. gillmanjr
    gillmanjr Member
    140
    Sounds like a pump issue one way or the other.
Share This Page
