Need Help With Buying Components For An Old Computer
2048Megabytes
What are the specifications of your current power supply? Measure the size of your present motherboard also. Be sure you touch the unpainted metal of your case before touching anything inside your computer case.
2048Megabytes
The specifications of the power supply should be written on the side of the power supply. You should be able to see it if you open up the sides of your case.
