Alrighty, so I am a little confused on how I am doing in regards to my processor overclocking. I think I have it quite stable at 3.0ghz (E2180) as I ran it on Orthos blend test priority level 1 for around 23 hours without it crashing. First, here are some screenshots of CPU-z and PCWizard just for some reference.
Alright, so the temperatures on PCWizard are my idle temperatures, and when I was running Orthos the temps never hit above 60 degrees, usually hovered around 55. What I am a little concerned about are my idle temperatures as they hover around 37-40 degrees and seems a little high considering the Zalman 9700 in use. My question is, as far as I know, voltages can increase temperatures, and are any of my voltages too high that may be making these temperatures any hotter than they should be?
I think my Vcore is pretty low as it is, should I attempt to lower it any further? As far as my ram voltages go, I added .4 volts to the default 1.8 on the mobo as my ram requires 2.2v, but I don't think it's getting the necessary volts? Little different here, but is PCI-E volting the same as volt modding on the GPU (because on my GPU there is a little volt mod thingy, Galaxy 8800GT)
All in all, how is everything looking? Anything I should change or be aware of?
Thanks a lot guys!
Thanks a lot guys!
