Need urgent help...PLZ HELP !!!
Sebouh
Hello. i dont know if this topic fits here but i have a big problem. I recently formatted my computer and i installed windows xp SP2 as i had previously. But this time i also installed Norton Antivirus 2005 with norton GoBAck 4.0 And Norton Systemworks 2005. So the thing happened is that, when i now try to download a file which is greater then 10mb or so, i cant get it completely downloaded(the download simply ends without completion). Sometimes if the file is large (60 mb) i can get 30% of it if (33mb) 70%.
I dont know why but the only change between my preformatted system and postformatted system is the nortons. I tryed to uninstall them but the problem continues. I dont know if my ISP has put an option to this. I have a (broadband connection and connect to a network to connect to the web).
So plz if anyone knows what my problem is tell me .
THANK YOU.
