I have just built a new system from scratch however i am having problems installing an OS.
I have built the PC everything appears to be correct, I have one hard drive assigned to Master and plugged in the master IDE slot, the PC boots fine i have it set to run from Disc so it boots windows set up and goes through this fine, it lets me format the drive and then begins to install windows files.
After doing this it says the pc will reboot and i let this happen however when booting back up if you let it pass the "press any key to boot from CD" it says there is a disk read error and press Ctrl Alt Del to reboot.
If i boot from CD again it just repeats the motions of installing windows again.
PLEASE HELP i have no idea what is wrong, could it be a hard drive problem?!?!
