not sure what is going on can anyone help me out
Lj8473
the problem im having is every time i open my cdrom drive or my dvdrom drive my computer will no longer let me access it to run the program i get an error when i click on the icon that says "D:\ is not accessible. The request could not be performed because of an I/O device error." when i check the drivers it says that its running fine but the only way i can get it let me use my cdrom is by uninstalling my drivers for each rom drive and then reinstalling it. i have tried to update the drivers and there were no updates i have gone into my bios to see if i could find something but im not very good in bios and didnt see anything i also tried to reset it by taking my cmos battery out. the people i have talked to said it sounded like a bios error but other than that it pretty much leaves people stumped so is there anyone out there that may know something
unusal problem i seem to remember fixing a cilents computer with same issues what type of computer is it?
what do you mean what type? i built it myself its an xp. intel core duo 6300 1.86ghz. i cant remember the name of the company that made the motherboard but according to my device manager its by a company called ACPI
i actually ment the brand off CD drive i think by memory a defrag and disk clean up and restart sorted it
