shadyi said:yes it says press any key to boot from cd .......
for like 3 seconds and then disappears
you have to press any key to boot from the CD
I dont see "press any key to boot from cd..." i just goes straight to the error screen
shadyi said:that's weird !
are you sure this is the right CD ?
and are you sure you set the first boot to CD-Drive !
shadyi said:do you have another computer to try it on ?
because i think the problem is in the CD itself
apj101 said:ok playkid you have to have done something wrong in the process, what you are trying to achieve at this point it for the computer to boot from the cd, and never even look at the hard drive. In fact take the hard drive out of the machine completely! and it should still boot from the cd just fine
