Just curious if anyone can explain what offset is?
does that just mean constant strength? or something like that?
I think by default my fans run at 30%
If i put my "offset" to 34% the fan runs at 60%
is this okay to do?
is there a preferred ratio of CPU fan vs Side fan strength%?
on another note about Temps, My Cpu never gets over 50degrees and the hottest i've seen my GPU is 55degrees, i've read that 65-85degrees should be fine so I think i'm more than okay. is that correct?
Gpu is a Geforce GTX 1660
Thanks in advance for any helpful advice.
is this okay to do?
