Parts specs
whatsmydingo
Ok, so I am planning on buying new parts: case, mobo, proc, and memory.
My friends have helped me pick out a few, but I would like some outside opinions, hopefully none that are too biased.
CPU:
AMD Athlon 64 3400+, 512k L2 Cache, The Only 64-bit Windows Compatible Processor - Retail
Model# ADA3400AXBOX
Item # N82E16819103484
Specification
Model: AMD Athlon 64 3400+
Core: Newcastle
Operating Frequency: 2.4GHz
FSB: Integrated int chip
Cache: L1/64K+64K; L2/512K
Voltage: 1.5V
Process: 0.13Micron
Socket: Socket 754
Multimedia Instruction: MMX, SSE, SSE2, 3DNOW!, 3DNOW!+
Packaging: Retail Box (Heatsink and Fan included)
Price: $287
MOBO:
MSI "K8N Neo-FSR" NVIDIA nForce3 250GB Chipset Motherboard For AMD Socket 754 CPU -RETAIL
Model# K8N NEO-FSR
Item # N82E16813130470
Specifications:
Supported CPU: AMD Athlon 64 processor
Chipset: NVIDIA nForce3 250Gb
RAM: 3x DIMM supports unbuffered ECC/ non-ECC DDR 400/333/266 Max 2GB
Slots: 1x AGP 8X/4X, 5x PCI
Ports: 2x PS/2, 1x COM, 1x LPT, 8x USB2.0(Rear 4), 1xRJ45, 1x S/PDIF Out, Audio Ports
IDE: 2x ATA 133 up to 4 Devices
SATA/RAID: 2x SATA RAID with 0,1,0+1
Onboard Audio: Realtek ALC850(8-Ch)
Onboard LAN: 1000 BASE-T Ethernet
Form Factor: ATX
Price: $107
CASE:
COOLMAX 400W CX-400B, BLACK, Taurus CX Series Silent Power Supply; 1 x 120mm fan, 3 Speed Fan Control Switch ( Auto, Low, Medium).
Model# CX-400B (Black)
Item # N82E16817159023
Specifications:
Type: ATX
Maximum Power: 400W
PFC: No
Power Good Signal: 100-500ms
Hold-up Time: Not specified
Efficiency: >65% at full load
Over Voltage Protection: on all output
Overload Protection: on all output
Input Voltage: 100~132VAC or 200~264VAC
Input Frequency Range: 47~63Hz
Input Current: Not specified
Output: +3.3V@30A, +5V@40A, -5V@1A, +12V@18A, -12V@1A, [email protected]
MTBF: Not specified
Approvals: UL, CSA, TUV, CE
Price: $38
ANTEC Performance Plus Metallic Gray SOHO File Server Case without Power Supply, Model "PlusView1000AMG"
Model# PLUSVIEW1000AMG
Item # N82E16811129124
Specifications:
Case Type: SOHO File Server
Color: Metallic Gray
Material: 1.0mm SECC
Drive Bays: 5.25'' x4,3.5''(External) x2, 3.5''(Internal) x4
Expansion Slots: 7
Front Ports: USB2.0 x2,IEEE1394 x1
Power Supply: N/A
Cooling System: 2 x 80mm Rear Fan
Motherboard Compatibility: up to Extended ATX
Dimensions: 20.6''x8.1''x18.6''
Special Features: Lockable side panel with high-clarity,scratch-resistant window,vent,and 80mm fan mount
Price: $66.50
MEM:
Corsair XMS Extreme Memory Speed Series, (Twin Pack) 184 Pin 1GB(512MBx2) DDR PC-3200 - Retail
Model# TWINX1024-3200C2
Item # N82E16820145449
Specifications:
Manufacturer: Corsair
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2-3-3-6 T1
Bandwidth: 3.2GB/s
Organization: two 64M x 64 -Bit
Special Features: With Black Heat Spreader
Warranty: Lifetime
Price: $225
Total (as of now -> not planning on purchasing until a few weeks before X-mas): $723.50
Nice setup ... note however that your setup is the discontinued S754 architecture (meaning it is not futureproof). of course the S939 is noticeably more expensive....
In that case, it's an excellent setup ... you might be able to get more if you went after a P4C-2.8 + i865PE hwoever
P4C-2.8 = Pentium 4 (NorthwoodC), 2.8Ghz
i865PE = a motherboard based on the i865PE chipset such as the ASUS P4P800
