Possible dead or shorted battery in tablet?
Da Mail Man
I Have an issue with a trio stealth - 10 mst10-21, 16gb memory tablet...Android OS.
Years back, I received this and decided to try my hand at replacing the cracked screen (digitizer) which
came out perfectly and applied a screen saver also.......
I had forgotten all about it and dug it out with factory power supply...I turned it on, booted right up...
Accessed my wifi with no problems...I saw that the batter was VERY low so, plugged in the power supply
and watched the screen "fad to black"...That's all she wrote...
Turning it on with the power supply plugged in - nothing happens...Same with "charging it" for 2 days, same results...
Took voltage measurement from power supply, checks good...
Is this battery past the point of no return>?...Suggestions?
