I was looking really hard at one of those 250GB drives. Then I looked at my bank balance and talked myself out of it pretty quick.
I probably ought not to have bought it, but I have a bit less self-control over my funds when somethings on a good deal. I usually don't regret it thankfully
Yes. You won't be booting to the sandisk so you can copy data over and then delete existing partitions.Am I going to be able to install and boot to Windows from the EVO and then format the Sandisk?
Also, I kind of thing that the USB it uses isn't bootable, you just run the setup from the USB drive. Not 100% sure, but I remember trying to boot from it and not being able to find it in BIOS and ended up just running the setup on the USB while in Windows.
You can do both
this new Windows installation/re-installation process and all of the options Microsoft gave us seems pretty damn cool.
