Power Supplie problem
Discussion in 'Computer Cases, Power Supplies and Cooling' started by snag, Nov 12, 2019.
  1. snag
    snag New Member
    28
    Power Supplie 600 thermaltaker was making noice , i replace that with thermaltaker 500 and the computer will not boot ,it will run turn off and turn on by itself,i am runing win 10 and 4 monitors.
    how i can make that run ?
  2. snag
    snag New Member
    28
    can i install the old power suply back ,will that work ? it was working fine only fan noice.
    what cose that stop booting ?
    if you replace power suply it should boot same like the old or you have to do somting with setup ?
  3. johnb35
    johnb35 Administrator Staff Member
    42,121
    Either new psu is bad or possibly a loose connection somewhere. Check 8 pin cpu connection and 24pin main psu connector.
  4. snag
    snag New Member
    28
    i checked the conection,i turn that on it start runing 30 second and turn itself of and on every 30 second,i had to flip the swith back to stop computer turnig on and of.
  5. johnb35
    42,121
    Did you build this system yourself? If so, are you sure the standoffs are installed correctly and in the correct spots?
  6. snag
    snag New Member
    28
    standoffs ,not sure whot you mean .that is for motherboard ?
    i build that few years back it was runing fine,somtime the win 10 put update on and it lock up,reboot few times and run week no problem.
Share This Page
