Power Supply for Monitor
Discussion in 'Computer Cases, Power Supplies and Cooling' started by Raywilk, Mar 2, 2017.
  1. Raywilk
    Raywilk New Member
    4
    First off, please excuse as this may be a 'stupid' question as I have little electronic knowledge. I have an AOC monitor and have just worked out the power supply is faulty. It is a 12V, 3amp transformer. I have been given one to try that is 12V, 2.8amps and the monitor works fine. I cannot keep this one and was wondering if a 12V, 5amp transformer would be OK. I'm just not sure how critical the amp rating is. Any help would be appreciated. Thankls
  2. mistersprinkles
    mistersprinkles Active Member
    959
    Its pretty critical. You dont want to mess with it. If its rated 12V 3amp, you should buy such a power supply and nothing else.
  3. Raywilk
    Raywilk New Member
    4
    I had a feeling that would be the case so thanks for the confirmation mistersprinkles.
  4. mistersprinkles
    959
    I'm not saying going out of spec will blow anything but it's always wise to stay in spec.
    Sabrent makes power supplies for stuff like this. They are cheap, decent quality, and they make one for EVERYTHING.
  5. Okedokey
    Okedokey Well-Known Member
    9,507
    It will work fine. It will only draw the amperage required, nothing more.
  6. mistersprinkles
    959
    How u no dis?
  7. Okedokey
    9,507
    Its basic electrical principles. Amperage is a factor of voltage (fixed variable) and wattage. The wattage required by the monitor will not change from one PSU to another and therefore the amperage requirements will be the same. So having a larger PSU you will not matter as it will only draw the same amperage either way. Important that the voltage is the same, and that the PSU is equal to or larger than the requirements.
Share This Page
