Power Supply Help.
Barker
I have an Acer Veriton M410, and I need a powersupply, as this one has gone bad. I accidentally threw out the other, So I can't really look at it. :mad:
I would really appreciate if you guys could tell me whether this power supply: LITE ON PS-6361-AHF would be a good one for this computer. Thanks. It needs to have SATA connecters and 24-Pin main connector.
You should have never thrown it away as it looks like the tower is a mini tower and it might need a smaller power supply. You might need someone to confirm what size specification you need for a PS.
mini ATX tower, Should fit standard ATX PSU. Or could use a ruler/ tape to measure it up?
Dimensions of an ATX power supply are 150 mm width, 86 mm height, and typically 140 mm depth, although the depth can vary from brand to brand.
I haven't heard of Lite on do power supply...
May be getting consair CMPSU-400CX or Antec NEO ECO 520C 520W
