problem with audio conversion
bm23
Hi. im new here and so, i do not really know where to put this question. i hope this section is appropriate enough. anyway, i have serious problem when it comes to audio conversion. i download many audio converter and try them all but to no avail. i would add audio files to the to-be-converted list. but no matter which software i use, it would say all files are converted the moment i press convert. of course, no file was converted. does any1 know what cause this problem? by the way, im using windows XP SP2. thank you
converting fom what to what ? you didn't give details ?
and make sure you are not converting protecting content like WMA as we wont assist you here,
and btw, WELCOME TO THE FORUMS, PLEASE TAKE YOUR TIME TO REVIEW THE RULES
well, i convert from .mp3 to mp3. i do so to reduce the bit rate. i specify the directory which the file should be placed in. the thing is, the software is not able to convert at all. like i said, it would report that the conversion is done but no file is converted. i suppose there is a problem with my computer, not the softwares as they were able to convert audio before. some of the softwares i use are Blaze Media Pro, SC audio converter...etc
