Problem with Nforce ms-6367. Help me, please
alex04
HI:
I have a MSI ms-6367 (Chipset: Nforce 220D - IGP 64/128) motherboard. I bought a Althon XP 2200+ CPU but the motherboard detects it as Duron TM 1800MHZ.
The Motherboard's manual says that it supports Athlon XP 2200+.
My Bios Version is 1.3 (date: 07/09/04)
How I solve this problem?
Thanks.
Tapir
Are you sure of that bios date??? Go to msi site and search for latest bios. Also after installing windows did you install the system drivers. I think the cd brings a utility program that helps you detect system problems and select the corret bios. If you need to flash be very careful.
