Problems with new build, plz help!!!!
superschan
I have just built a new system but have been unable to install windows on it.
I am using an ASUS P6T DELUXE V2 board and on the Asus website it says PC3 12800 (DDR3 1600Mhz) is supported with overclocking so I got a triple channel kit of OCZ PC3 12800 6GB memory to go with it and when I try to install windows it just keeps going to the blue screenm is the memory where the fault lie???
PLZ HELP!!! ANY IDEAS APPRECIATED!!!
The parts I used are:
Asus P6T Deluxe V2
Intel Core i7 920
PowerColor HD 5870
OCZ PC3-12800 6GB triple channel kit
Corsair HX 850 PSU
You can test each strip of RAM individually to see if you can identify if one of your DDR3 memory stix is bad. Your MOBO manual should tell you where to put the RAM for single channel.
If one of the strips - your PC functions normally - with one 2 strips individually - and the third causes problems - that could be your answer.
2gb is enough for windows to install and run on. just put in one stick, see if it works if it does, then that stick is good. then add another stick, etc
Asus P6T Deluxe V2
Intel Core i7 920
PowerColor HD 5870
Corsair HX 850 PSU
To run it at 1600 you probably need to go into the bios and set the voltage and timing.
