PC Hobbyist
[-0MEGA-];765224 said:Looks interesting, but I have no idea how it would work since laptops dont have a VGA input. Unless it just uses a USB connection.
They say it installs a virtual VGA driver in the primary PC, then in the target pc or laptop, it uses a small (900 KB) viewer program (that apparently you don't need to install - it just needs to be there?? and when you're done you can just erase it if you want, leaving no traces). The signal is sent from the virtual driver to the target computer via LAN (wireless or ethernet) and the viewer file displays the contents on the entire screen.
You can even use it with a Tablet PC and you can hook up to 4 "monitors / pcs"
It works fine with XP, but there are limitations with Vista because of Vista's increased security. You can read about those limitations in their "system requirements" link on their webpage. Interesting concept. I didn't know about it. Not a bad idea if you have a laptop laying around.
