Sabertooth x58 water cooling block and case advice?
Discussion in 'Computer Cases, Power Supplies and Cooling' started by YourDigitalJester, Feb 12, 2017.
  1. YourDigitalJester
    YourDigitalJester Member
    96
    Im starting to dive in to the relm of overclocking, and my stock case and cooling arent up to the task, anyone know where i should look? My budget is somewhere around 300, though id like to spend as little as possible for a reliable system
  2. Laquer Head
    Laquer Head Well-Known Member
    6,226
    If I were in the market for a WC kit I'd be looking at EKWB.
    And thats IF I were looking into WC kit..I personally don't see spending 100 on a Corsair or over 200+ on some kits is offering much difference.
    If your mainly concerned about the CPU, I'd look at Corsairs AIO lineup, as well as, EKWB predator lineup (albeit more expensive)
    EKWB Kits
    Corsair Kits
  3. Intel_man
    Intel_man VIP Member
    5,774
    I wouldn't bother with a custom loop on a X58 platform now. Just grab a Noctua D15.
  4. Laquer Head
    6,226
    This too^^
    A simple AIO or good air cooler will solve alot of issues for you with heat.. ohh and new thermal paste!! ;)
  5. YourDigitalJester
    96
    Might just do that and save the expense
    Laquer Head likes this.
  6. YourDigitalJester
    96
  7. Laquer Head
    6,226
    Definitely makes sense...
    And most of the coolers and aio kits, as well as being cheaper price, can also be reused in a new build (socket compatibility required)
  8. Intel_man
    5,774
  9. YourDigitalJester
    96
  10. Intel_man
    5,774
Share This Page
