either would be fine. Switches will send traffic out the correct ports by MAC address (Layer 2) hubs just flood all ports. If you are buying new, get a switch.
Get a switch. Yeah, you should be fine. I set up my son with internet at SIU about a month ago and used a switch and said that was fine.
Where do you usually get your parts from? Any decent brand will be fine.
http://www.amazon.com/GX1005B-V4-po...=UTF8&qid=1378862991&sr=1-4&keywords=switches
I have an earlier version of this switch and have had no problems.
Either one should work fine.
What is the internal IP of the first router? For example, if the first router has an internal IP of 192.168.1.1 then set the internal IP of the second router as 192.168.1.2. disable dhcp and leave wireless on if need be. Connect a cable from lan port from router 1 to lan port on router 2.
Only users on your network will be able to access the second router by entering the IP address. I had 3 routers hooked up and was able to access all 3 just by entering the IP. Now I only have 2 hooked up.
Nope, its not gonna matter as all the IP adresses will be coming from router #1.
So if router 1 has an IP of 192.168.1.1 then all devices attached to your network will be the following.
192.168.1.101
192.168.1.102
and so on and so forth.
Look in your first image you posted. See where it says start IP address?
Thats where your user IP addresses will start. You can set that at any number you wish and then below that it says maximum users, can set that to whatever you want to.
subnet I believe should be the same as router 1.
