Solid State Flash Drive or Hard drive?
A solid state drive is still very expensive for the amount of memory it gives.
On the other hand it is VERY reliable because there is no reading head which can break.
If you don't need more then 16GB ... go for it man you won't regret it because you can give those small netbooks a hard trip sometimes. :P
Well i had the choice of a Solid State when i was looking at getting my Lenovo S10 netbook,Although i choose a 80gb hard drive instead.
Just dont see the point in having a super fast hard drive when all the netbooks are designed for realy is basic internet use.
And they load up quite fast anyway with just a standard hard drive.
i say go with the standard hard drive. :)
