I just built a new pc with a chaintech vnf3-250 motherboard and installed win xp home and I can't get the sound to work at all. The mobo comes with onboard sound and also comes with a CNR card to support 5.1 surround sound. motherboard specs show AC 97 codec (I don't know if this is the card or onboard)
I have installed the drivers and everything looks good (no exclamation points in the device manager) set to default, turned on, speakers plugged in, volume up, but no sound.
I deleted and reinstalled the drivers - no luck
pulled out the cnr card, deleted and reinstalled the drivers - no luck
put in the cnr card, disabled onboard sound in the bios, reinstalled drivers - no luck
enabled onboard sound with the cnr card in, reinstalled drivers - still no luck
I tried headphones also to make sure the speakers weren't to blame, still doesn't work.
anyone know the answer or have other suggestions on what to try?
I don't have another sound card to try or another pc to try this cnr card in, but I guess I may have to buy a new sound card.
Thanks,
Sven
Thanks,
Sven
