Cthulhuspawn82
I just got a new computer and I can’t get the sound to work on it. I was wondering if anyone could help. First, let me give some info on what I think the problem isn’t.
My speakers and subwoofer all have power and are working fine. I just transferred them from the old computer. Also they are set up correctly, the subwoofer connects via the green audio out connection on the computer and the and the speakers connect to it.
The volume on the computer is turned up and the little sound bar confirms that sound is playing. You know that little bar that goes up in down as sound plays.
The computer says that the “Digital output device (SPDIF)” is properly working
This was also a floor model in the compUSA I purchased it from. It was hooked up and sound was playing there. Of course it was hooked up to a big TV, could the sound have been coming from that?
Final bit of info, my motherboard is a nForce 680i SLI. I believe the sound the computer is using is just the on board sound.
Oh and I am running windows Vista.
The only thing I can think of is that I need new speakers that are compatible. But also, my headphones don’t work on it either.
