smartpoints
My system was quite loud, so I decided to invest in some high quality fans, unfortunately, these fans are 3 pin (voltage + tach), whereas the computer's current fans are 4 pin (voltage, tach + PVM control); I know, should've looked first . Is there any way that i can run these fans and maintain the speed control that the system already has.
Thanks for your help.
