system help
I used Spybot and Avast to clean up my system from Malware and Viruses.
Now every time I startup my computer I get this massage.
ERROR LOADING
C:\WINDOWS\SYSTEM32\IEJORUDE.DLL
The specified Module could not be found.
And I click OK Tab because that is the only one there and it goes off screen and all work good.
Wen I restart it happens again??????????????????????????
Please follow this procedure and post the logs.
Please download Malwarebytes' Anti-Malware from here, here, here or here and save it to your desktop.
  • then click Finish.
  • If an update is found, it will download and install the latest version.
If you continue to experience problems after doing this, please post a HijackThis log by doing the following:
