Tech Guide: Diagnosing a PC which will not POST or Start
Discussion in 'Desktop Computers' started by spirit, Apr 15, 2012.
Thread Status:
Not open for further replies.
  1. EINREB
    EINREB Member
    226
    Yes, I am using a Cooler Master GLITE case, which came with the required standoffs.
    UPDATE Just to check, I installed an older board (ECS A740GM-M) in this new case (using the same hardware), with the pwrsupply, HDs and CD I was using before, and it is running OK right now. So it sould not be the powersupply that is the problem
    Same question remains, which is the bad part, the MoBo or the processor?
  2. spirit
    spirit Moderator Staff Member
    17,364
    Processors rarely really go bad unless you break one of the pins whilst installing it, so I'd say the motherboard is likely bad.
    Just to make sure it isn't shorting on the case can you try and run the motherboard outside of the case on a cardboard box or a large book or something?
  3. EINREB
    EINREB Member
    226
    Yes, that is what my first thought was too.
    BTW it is hard to force the processor into the socket, as long as you have it oriented correctly and open the lever all the way, it just drops in. At least mine did.
    Before I return the MoBo, I will follow your suggestion and assemble everything outside the case. I tested an other computer that way and even used it for a while before I bought a case and packaged it.
    See what happens.
  4. spirit
    17,364
    Yes I know it's pretty much impossible to install a CPU the wrong way.
    Do try it outside of the case. If that doesn't work, I'd support the view that you have a bad motherboard.
  5. EINREB
    EINREB Member
    226
    UPDATE 2: Now the previously assembled test setup that was working fine, does the same thing as the original assembly: it will not power up! There must be something wrong with the pwrsupply afterall!
    Unfortunately, I do not have a spare available, and have to buy a new one to get this project going. Assembling it outside the case does not make much sense now, I am not gonna use a pwrsupply that is unrelaible. Have to wait until there is some cash available to do buy one, did not count on this possibility.
    Thanks fellows for your advice. Keep you informed as what happens.
  6. spirit
    17,364
    So hang on you put a new build into the case? If so, I reckon the issue is with your case or possibly the I/O shield.
  7. EINREB
    EINREB Member
    226
  8. spirit
    17,364
    This is the I/O shield plate.
    [​IMG]
    It may cause problems if it's not installed correctly.
  9. EINREB
    EINREB Member
    226
    Thanks, spirit. Yes, I know that shield. Just did not know how it was called.
    The latest failure I had the assembly did not use this shield. I lost it somewhere when I retired the MoBo a year ago. So it can not be that.
    BTW, How can it give troubles?
    Beside getting a new powersupply, the only option I have now is to pull a pwrsupply from one of my working computers and assemble the parts outside the case as you previously suggested.
    I might still do that later on.
  10. spirit
    17,364
    Well what could have happened is the lack of I/O shield could have meant the board was possibly making contact with the bottom of the case and shorting - that may have been the cause.
    My understanding is that the I/O shield does ground the board, so if it's not installed correctly or not installed at all your board may short on the case possibly.
    Yes try re-building the system out of the case using a known working PSU.
  11. EINREB
    EINREB Member
    226
    Thanks. Will do so. Keep you informed as to the results.
  12. EINREB
    EINREB Member
    226
    UPDATE - Got a working PSU and tried the system outside the case. Same result. No signs of life. No POST beeps or anything on the monitor.
    I have send MSI an email requesting a RMA to return the board. Hope that they will honor their Warranty, it is less than 2 months old.
  13. spirit
    17,364
    Sounds to me like you definitely have a bad board then. :( Hopefully MSI will RMA it for you.
  14. Calin
    Calin Well-Known Member
    1,555
    Best guide ever!
  15. spirit
    17,364
    Thanks, I appreciate it! :)
  16. Xwardos
    Xwardos Member
    145
    very nice....well done mate. you'll be an admin in no time :p
  17. spirit
    17,364
    Thank you! I appreciate it! :)
  18. Okedokey
    Okedokey Well-Known Member
    9,507
    Necro'd by a spammer.
    Still a stellar guide!
  19. spirit
    17,364
    Thank you! :)
  20. Cgoggz56
    Cgoggz56 New Member
    11
    Awesome guide. I have two laptops that haven't given me trouble with booting, but this is great information to have.
Thread Status:
Share This Page
