Upload Speed! When do my Download speed gos slower?
Scrapped>.<
hi
Do anyone know how many percent of the upload speed that can be used with out slowind down the download speed?
My download speed is 1.5MB
I am not sure about my upload speed in Bites but i think it is about 42KB/s
thanks every one
Depends on your connection and its not a fixed percentage because any uploading activity will cause your DL to decrease
If you're on a 1.5MB line (which costs in the order of several hundred dollars per month) and youre only getting 42KB/s upload then definitely call up and yell at your provider!
:rolleyes: That sounds fun. i will try it. :D
thanks
By the way r u the web master? Just wondering :P
1.5MB is 8 times larger than 1.5Mb, and usually internet speeds are measured in bits per second. So being on a 1.5MB line is amazingly fast. (I think)
For a household line i think the most you can get is a ADSL 8Mbit (real 8mbit -- the same as the corporate stuff as opposed to your normal, highly variable highspeed lines). It still runs in thr several hundred/month bracket.
