lukecook2410
Help, I've recently upgraded my PSU because the PC would randomly loose power. The new psu didn't work until 24hours after installation I randomly came down and turned it on. Then after a few hours of using the pc, it shut down...
Since then I've had no luck... So I replaced the motherboard... No Luck... So I bought a new case thinking it might be the switches nothing again, then I bought another PSU and same again. The PC shows no signs of life at all!
I've tried with just 1 stick of ram, without the dvd drive and hard drive, and graphics card... Could it be my CPU? There is absolutely no power at all. It is like there is nothing coming out of my wall (I have tested the outlet and tried 2 different plugs which previously worked and still do to my knowledge.)
I am now honestly stuck as to where to go next... all help greatly appreicated, this is majorly frustrating!
Thanks
Thanks
