Volume bar not showing up on my monitor
Hi PC H,
In the event that HP doesn't have a solution to my problem, after a hard drive reformat, I just won't download the KB913580 update. I will be turning off windows auto-update too.
By turning off windows auto-update, I'll be getting the red shield on my system tray warning me that my "computer might be at risk". How do I stop this message from popping up at start-up?
By the way, deleting the update did not do anything on my system as well.
If you absolutely do not want Automatic Updates at all, go to Start->Run type services.msc Look in the list for Automatic Updates, then Disable it, then Stop it. Voila!
unicron said:
I would like to thank everybody who have responded to my post, especially PC Hobbyist.
You're very welcome, unicorn. I'm glad I could help out since I went through the same situation. Hopefully you'll get your green bar back just the way you like it. :)
