scorpioncbr
The other day i spilled about half a glass of water on my laptop, there was no weird noises or smells and the computer stayd on, i dryed the water off the keys and tilted it so the rest could drain from it. i then turned it off and let it to dry for 3 days. now the computer turns on perfectly fine but most keys (w, ctrl, alt, delete, left arrow, and others) don't work. I cant get it to start because it won't recognize the cntr key. I use a fujitsu siemens celsius with windows xp.
is there anything i can do? anyone had the same problem?
Is there a way to use a usb keyboard even though i can't load it? will the comp recognize it?
i wanted to remoce the keys but i noticed that on this laptop they can't be removed. what can i do? please i need your help to get it to start up again.
Thanks.
Thanks.
