In my job I use several webcams and scanners.
If I am using only one it seems to work OK, but if I have to disconnect one and plug in another or have two of them plugged in at the same time, look out!
What I also do not understand is how under the Windows Control Panel>the Scanner and Camera Plug-in works. It is rare that all of the cameras and scanners show. It would be nice if they were treated like printers and would show what was attached, then you could install and remove a scanner or camera or set properties.
Any Ideas...am I doing something wrong? Can I clean up my USB ports?
