Captain Kirk
Hi folks
The systems that I am running:
Dell Latitude D610
Compaq Evo N610c
If I get a new hd, I need one that has the RAW ide pins available, not a SATA or some peice of plastic over the pins that cannot be removed to expose the pins underneath. Reason: If I switch the hd between my two different model computers, I need to be able to plug in the RAW ide pins to the plastic interface connector that fits onto the pins "before" you put the hd into the laptop.
will a Interface: DMA/ATA-100 (Ultra), run on either of these computer systems, or have RAW ide pins exposed?
Dell Latitude D610
Compaq Evo N610c
