Will these parts be compatible?
donald
I'm away to build my first computer solo. I have built computers in the past but with help so I need a bit of advice if these parts will all work together or not , many thanks :)
http://www.xcase.co.uk/X-Case-Stardust-Blue-Neon-With-Psu-p/case-stardust.htm
with PSU and support for atx motherboards
£38 case
Processor
AMD 2.9Ghz x 2 dual core £109
socket am3
1gb ram667 DDR2
http://www.3000rpm.com/acatalog/AMD_Dual_Core_Processor___Motherboard___Memory_Bun.html
DDR2 RAM 2gb 800 £40
http://www.3000rpm.com/acatalog/Team_Branded_2_Gig_DDR2_800_Memory.html
DDR2 RAM 1gb 800 £18
http://www.itcsales.co.uk/acatalog/info_3789.html
Blu ray drive
http://www.itcsales.co.uk/acatalog/info_2090.html
£40
DVD RW drive * 2
£9
http://www.itcsales.co.uk/acatalog/info_2340.html
500gb hard drive
sata £33
http://www.3000rpm.com/acatalog/Maxtor_500_Gig_SATA_Hard_Drive.html
Graphics card
Asus 512mb £28
http://www.ebuyer.com/product/174131
What powersupply are you going with? and also, i may be missing it, but i don't think you posted a motherboard either
Don't order stuff all over the place, you'll waste money on shipping
RAM - Get same brand and run dual channel. And it don't worth to get DDR2 anymore
Where is your PSU?? http://www.ebuyer.com/product/135159
http://www.ebuyer.com/product/168975
http://www.ebuyer.com/product/185913
http://www.ebuyer.com/product/192049
http://www.ebuyer.com/product/172638
http://www.ebuyer.com/product/158860
http://www.ebuyer.com/product/227080
Video card - I assume you are not gaming? Will you hook to TV? 4350 with HDMI out
http://www.ebuyer.com/product/169294
