So I have ordered a build, and I realized it might be best for my apartment to be wireless. My main aim with connection quality is gaming. I will be using the computer for everyday use as well.
For games in general, I plan on playing Starcraft2 and FPS, is going wireless a bad idea, and it is a good idea, what is a budget card that will provide me with confidence and stability in my connection. My apartment has a typical linksys router, which seems to work despite its environment and 1 broken antenna.
My older desktop does not get good reception from it, but I don't think it gets good reception anywhere, so assuming I have an average linksys router that works average, what would you guys say?
As a side note, I am also considering a webcam and a keyboard, so if there are any good bargain webcams that might be worth noting, keyboard I would assume is all preference assuming quality.
thanks,
-Andy
this is the setup I ordered
thanks,
-Andy
$645, exclude shipping.
Phenom II x4 955 + XFX HD-577A-ZNFC Radeon HD 5770 combo
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.415601
GIGABYTE GA-870A-UD3 + GeIL 2 x 2GB DDR3 1600 combo
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.424666
Seagate Barracuda 7200.12 ST3500418AS 500GB + HEC Blitz Black Steel Edition ATX Mid Tower combo
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.413256
OCZ Fatal1ty OCZ550FTY 550W + LITE-ON CD/DVD Burner - Bulk Black SATA Model iHAS124-04 - OEM combo
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.419457
I am not sure what style of case you want, just find one with combo deal
