Wrong power supply for my mobo?
dcb91
I was reading some reviews on Tigerdirect about the 24 to 20 pin adapters you can buy, and some guy said the adapter isnt necessary b/c you can plug the 20pin cable from power supply directly into a 24 pin MOBO, leaving 4pins open. Will this work? can i do the same for the wierd 8pin CPU connector with my 4pin connector?
The_Other_One
You probably will need that 8pin plug. However, your friend is correct about the 20pin ATX plug. Many motherboards will work just fine with a 20pin power supply, assuming you have everything else required...
I'd just get a new power supply. Most any new one has a 20+4pin plug. Sites also typically show all the connections, so you can see if it has the 8pin plug as you require.
dcb91
ok thanks, i will just get a new PSU then. i dont wanna risk it with my new motherboard.
