bldgengineer
I'm having a problem connecting to my RDC at work from home through IE. I can connect on another computer that's hooked to the same router but at home its like the firewall is blocking access as all I get is that the connection is timed out.
I have verizon dsl with a westell 7500 modem/router that the 2 computers are hooked to. I only need to connect to one (PC A) remotely through the web. I have forwarded the port I assigned to PC A on the modem and created a static NAT for the IP on PC A. Also, I opened up the port in windows firewall.
According to verizon, I have a static modem IP and the modem assigns different IPs to whatever is connected to it and each gets a different IP every 24hours. Using a static NAT I am keeping PC A at its current IP.
Can anyone tell me what I'm doing wrong with trying to connect through IE at home or anywhere else? I need to be able to see this computer from anywhere.
Thanks!
Thanks!
