davidlee928
Hi
i want to learn about computer hardware and stuff because i consider myself a gamer...i guess everyone needs to start from somewhere so i guess i'll start from here lol
Right now according to my friend i have a CRAP computer...these are the details for it:
Inte(R) Pentium(R) Dual CPU
E2160 @ 1.80 GHz
1.80 GHz, 1.00 GB of RAM
and i use a ATI Radieon HD 2400 series vid card
My first ever piece of hardware i might be buying is this vid card (OR GO TO THIS WEBSITE: http://www.itestate.com.au/products_detail.asp?code=PD00005608):
ideo Card PCI-e (nV) 9600GT 1GB ASUS EN9600GT/HTDI/1G
Feature: - 1GB DDR3 memory on board
- ASUS Exclusive Glaciator Fansink
- HDMI Supported
Specification: Graphics Engine NVIDIA GeForce 9600GT
Bus Standard PCI Express 2.0
Video Memory DDR3 1G
Engine Clock 650 MHz
Shader Clock 1625 MHz
Memory Clock 1.8 GHz ( 900 MHz DDR3 )
RAMDAC 400MHz
Memory Interface 256-bit
DVI Max Resolution 2560 x 1600
D-Sub Output Yes x 1 (via DVI to D-Sub adaptor x 1 )
DVI Output Yes x 2 (DVI-I)
HDMI Output Yes x 1 (via DVI to HDMI adaptor x 1 )
HDTV Output (YPbPr) Yes
HDCP Support Yes
TV Output Yes (S-Video to Composite)
Adapter/Cable Bundled 1 x DVI to D-Sub adaptor
1 x DVI to HDMI adaptor
1 x HDTV-out cable
1 x Power cable
1 x S/PDIF cable
Software Bundled ASUS Utilities & Driver
and i'll be getting it for $215 dollars (aus)
i was wondering...because this is like my first time...would this piece of equipment work on my computer?? or is there something that my computer doesnt match or have that can support this vid card??
ALSO last question!!!
About RAMS...i thought RAMS were just any chips that you get to shove into your computer somewhere...with the computer I HAVE what type of RAMS can i only use????
i'd appericate if someone took 10mins to help a noob out here
plz go easy on the technical words about computers because iam still new to this... THANK YOU ^^
E2160 @ 1.80 GHz
- HDMI Supported
RAMDAC 400MHz
HDCP Support Yes
1 x HDTV-out cable
1 x Power cable
1 x S/PDIF cable
