Mitch?
banned
I have a question for those who are saying AMD processors are good for budget builds:
How do you respond to the fact that Intel's Celeron Dual-Core and Pentium Dual-Core lines outperform, cost less, use less energy, and create less heat than comparable AMD processors?
It would seem to me that the only conceivable reason to buy an AMD processor is to support them in an effort to avoid an Intel monopoly.
no. no. no.
AMD 5000+ (BE or not) is 65w 2.6ghz and very oc'able.
Intel E2200 is 65w 2.2ghz and also oc'able.
Pair either up with a board of similar specs and AMD comes out ahead, the quality of motherboard/price ratio is way in AMD's favor. Especially if your going for an upgrade, as most AM2 boards are now AM2+, naturally at a good price, compared with loads of Intel chipsets that can't handle 45nm.
