Hello everyone,
This is my first attempt at building my own computron and was hoping that I could seek your guys' experience with compatibility. Below are the parts I picked out, and I suspect that they are all compatible, but unfortunately I am unexperienced and could be wrong.
Case:
NZXT Apollo Black SECC Steel Chassis ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146025
HDD:
Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
Video Card:
ZOTAC ZT-88TES3P-FCP GeForce 8800 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500006
CD-ROM:
LITE-ON Black 52X CD-ROM SATA CD-ROM Drive Model LTN-52S1S-10
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106038
Sound card:
Creative Sound Blaster SB0570 Audigy SE 7.1 Channels 24-bit 96KHz PCI Interface Sound Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102002
Power supply:
OCZ StealthXStream OCZ500SXS 500W ATX12V / EPS12V Power Supply 100 - 240 V
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341012
RAM:
pqi TURBO 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820141366
Motherboard:
MSI P43 Neo3-F LGA 775 Intel P43 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130185
CPU:
Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
As for my last two questions, I was wondering if another set of those RAM sticks also be compatible, and if anyone has suggestions to parts that cost less but work just as (or nearly) as effective? I'm trying to keep my budget low.
Thank you all for your help
Case:
HDD:
Video Card:
CD-ROM:
Sound card:
Power supply:
RAM:
Motherboard:
CPU:
