SnoopSanders
So I'm looking at HP notebooks because I need an upgrade and I'm trying to figure out which one of these to get.
The Intel notebook, with a lesser video card...
http://www.shopping.hp.com/webapp/shopping/computer_can_series.do?storeName=computer_store&category=notebooks&a1=Category&v1=Versatile+performance&series_name=dv6700t_series
-I would get the 2.4 ghz processor and the 8400gs GPU
Or the AMD notebook, with a stronger video card...
http://www.shopping.hp.com/webapp/shopping/computer_can_series.do?storeName=computer_store&category=notebooks&a1=Category&v1=Versatile+performance&series_name=dv5z_series
-I would get the 2.2 ghz processor and the HD3450 GPU
I really don't have enough knowledge of processors to figure out which one is better. I have never used an AMD before and I know they have some different qualities that Intel processors don't have. I do however like the fact that the AMD notebook has a better GPU and is cheaper, I just would like to know if it would be a good choice to go with the AMD. BTW, I'm going to use this computer for mostly school work and I do some gaming too, not extreme gaming though, I don't mind playing on low quality setting if I need to.
Also, I have only looked at Gateway, Dell, and Alienware laptops and if anyone has any other suggestions I would be open to them. These are just the ones I liked the best so far.
Thanks.
Thanks.
