9600GT or 8800GS, come to mind here.
well nobody ever asked what your budget was, so i'll go ahead and ask. because if you can afford $200 then you cannot do ANY better then the AMD 4850. if you can afford $300 then the 4870 is outstanding.
http://www.newegg.com/Product/Produ...lickDeals-_-NA-_-NA-_-NA&Item=N82E16814102747
use coupon VGA7820
Good deal within your budget.
the raidons (i think that is the spelling) are very good now!
you mean Radeons?![]()
