Will this video card be able to support this 24" monitor?
http://www.computerforum.com/125438-will-video-card-able-support-24-monitor.html
well bro, with only 1 video card you can support up to 19" monitors, you'll need crossfire for that 24 incher :COOL:
dude you have no experience with pcs whatsoever,im not saying im exactly full of knowledge when it comes to pcs either but i dont shout out some advice if im not sure if its correct or not.
what you said is compleatly untrue.....if you think its true then why am i running a 20" on 1 8800GT? i can run 2 ;)
not handles it
I think to get good frames, get crossfire (2x4870)
A single 4870 is good to, and you will have the option to CF later if you want
That's true. You definitely don't want to run that resolution with that card (the 9600 GSO). Dual 4870s' would be a good setup for that res.
what do you mean?
30@ with that resol and 4870 in cross fire is a mad mix? i havnt heard anything bad about it at that resol
No, no. The member I quoted asked about a 9600 GSO...
Yeah, a bit of confusion with my previous post. Sorry about that. :o
