Inexpensive Laptop - Budget 500-- TOPS
cool, what do you think of the processor? dual-core t2370 1.73 ghz??
will this stand up to a core2? or should i keep looking??
David
Like I said in my previous post, the T2370 is like Core 2 Duo, but it has lower cache memory... Thats the only difference. So yea it is a good processor
**** macs, I will never buy one, they are slow they suck my wife has a macpro with a 30 inch monitor i hate looking at it, it sucks. So that is out of the question... As far as an acer, I mean wtf? 550 and I still get only 1 gb of ram? I will upgrade but still, I mean 1st off if it comes with vista I am straight away downgrading to xp theres nooo way i am running that piece of crap os.
Also, I am bring my budget up to 650 what would u recommend I do now??
Thanks again for the help,
David
Macs are faster than PC as less processes are being used and why do you hate looking at it too big for your eyes:rolleyes::confused:
3 NOw
Agreed... I don't think I've ever seen a 'slow' mac???
Even the g3s are pretty fast by todays standards.
I dont care about macs, neways
on to what im currently now thinking about buying... it is between these 3
Lenovo Thinkpad Core Duo T2370 - 549.99 after 50.00 Rebate
Fujitsu Intel Core2duo T5450 - 599.99
Toshiba AMD Turion 64 - 599.99
what does everyone think my best bet is?? They are all at 599.99 except for the first with a mail-in rebate...
Thanks
your not helping go to a mac discussion board or something but this isn't the place to post... They are too expensive, find me a mac for under 600 that has at least a 120 gb hard drive and I may consider it, other STFU
Mac Mini. Wait damn Thought you ment desktop. Anyhow a 500$ Vista laptop wont get you far so think about that.
Eh this isn't a pc forum.
last time I checked the majority of the conversations on this forum are pc based (ie. 90 %) so if someone tells you they DON'T want a mac, then go somewhere else and badger... Also, I gave you a chance to find a 600 or less mac that was comparable to a pc laptop.. If so, I will consider, otherwise, as i said, THEY ARE TOO EXPENSIVE.
O and btw if you think your gonna show me some used mac on ebay that is 2 years old, forget it, I would not buy it if my life depended on it, I can find a NEW pc laptop for as low as 400 so why would I buy someone used on ebay of all places??!??
yeah..
i don't wont used to stock waisting my time, btw I found a laptop, its a fujitsu, and I got the one listed here, but only I got it for 466.00 instead of 599.99
