(little bit off topic but) Why don't they make SATA connection more sturdy? they always seem so flimsy and loose to me, I usually cable tie the power lead and drive cable together around the plugs to give a bit of stability![]()
I've never had that problem but new cables have a locking clip to hold the cable on securely.(little bit off topic but) Why don't they make SATA connection more sturdy? they always seem so flimsy and loose to me, I usually cable tie the power lead and drive cable together around the plugs to give a bit of stability
I said they seem loose to meabout the sata cable falling out.... unless you move your computer from place to place or stick your hand in the case the sata cables shouldn't fall out.
