what are your specs and what do you use your computer for? we'll let you know if its worth it to upgrade then.
Alright thanks this is what I was thinking
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131299
mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16814103064
video card
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115041
Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227298
Ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148294
Hardrive
Cant decide between antec 1200 because then I can combo the psu http://www.newegg.com/Product/Product.aspx?Item=N82E16811129043&Tpk=antec+twelvehundred
or this case and then a psu http://www.newegg.com/Product/Product.aspx?Item=N82E16811103014
and then I wasnt sure on a cd/dvd drive
Those are pretty nice specs, if you upgrade your videocard to something like the Radeon 4870 the computer will last until the price of Nehalem setups coms down enough so you can get yourself a new build.It has a q6660 which i ocd to 3.2ghz 4 gigs of corssair mem and an 8800gt.
Most even remotely demanding games utilize at least 2 cores now. If they only run a single thread, chances are the thread won't need all available processing power of even one core of a yorkfield.Nehalem won't be a lot faster than Yorkfield in single-threaded applications such as most games.
I dont know if you saw or not but I had to return that computer so Im stuck with none now.Those are pretty nice specs, if you upgrade your videocard to something like the Radeon 4870 the computer will last until the price of Nehalem setups coms down enough so you can get yourself a new build.
