go through all the settings on the RAM and make sure they are set to auto.
when bubblescivic had problems with clocking his, I found that the advanced timing settings for the RAM had some weird settings.
[-0MEGA-];1052913 said:Maybe I'm confused, but when you raise the FSB say 5MHz, what happens? Does it not boot or does it not register the overclock?
Try resetting the CMOS via the jumper, it worked on my X48 when the computer wouldn't boot when I changed the voltage.
are they channel A/B timing and driving settings set to auto?
if that won't work, what BIOS version do you have? Maybe flashing the BIOS to the newest version would help, I'm not sure.
and also, will the computer POST if you set the FSB to 333 manually with the CPU host clock control enabled?
all fixed..put the bios back to f3 overclocks like a beast..no voltage change 3.6 ghz check out the pi
