Looks great! Nice work!
What's the key for? I think it'd look really good sprayed all black, do you plan on painting it?
Turning it on. And I'm not sure about painting, I might if I find the time. I would really like to seeing that some of the (crappy) paint job was scratched during my modding process. However I am not too confident about my painting abilities yet.
Ah right, Cool. So there isn't going to be a power button?
Did you see the thread I made about painting my case? That was the first time I'd every sprayed anything, and it came out far better than I expected it to, it's really easy!
sanding tit you have to do
Well the original button is still going to be there, but I haven't decided whether to hook it up or not.
And yeah I saw that thread. How much sanding tit you have to do, and also how many layers did you spray?
I actually didn't do any sanding. I degreased it all then applied a very thin coat and then did several others that were a little thicker.
lol.
So there are no other mods for this thing?
I think I'd like to see it when you put everything inside.![]()
didyouknowthat, remember that if you do ever want to connect your power switch (the original one in the case) I'm not sure but I think it'd have to be a 3-way switch which means you can turn it on/off from two locations. At least that's in light switches for example, if you have a ceiling lamp in your stairs, and you want it to turn on/off from 2 different switches (main floor and 2nd floor) the 2 switches would need to be 3-way switches.
And I don't think there's momentary 3-way switches so...
